FLRIG WSJT-X XieguG90 problems
surfking
I have followed every Youtube video discussing the setup for FLRIG to control my XieguG90 and work with WSJT-X. I am receiving signals and decoding them just fine. FLRIG works fine for controlling the XieguG90 but when I launch WSJT-X and transmit it does work once and then FLRIG locks up. Not sure how to resolve this. Any help is welcomed.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
I've submitted a request to move this to our amateur radio data transmissions forum where it's more likely you will get help.
Is FLRig set up to work with the G90? If it isn't, then that's your problem, however....
FLRig is part of the FLDigi family of apps, so perhaps you would be better off asking in the Win-FLDigi reflector on groups.io....
MIke
popnokick
Northeast PA
I use the same Windows computer for both FLRIG and WSJT-X. HOWEVER (with my computer anyway) it is not possible to run both programs at the same time since they conflict with each other over serial port communications. Before I launch WSJT-X I must first quit FLRIG / FLDIGI... and vice-versa.
AK9R
Staff member
Super Moderator
Central Indiana
...it is not possible to run both programs at the same time since they conflict with each other over serial port communications...
This. With serial communications, only one terminal can be in control at a time unless you use some sort of port sharing and conflict mitigation protocol.
