John_M
How do these effect us scannists. While doing some researching I stumbled upon some filters to wipe out this band.
milf said:Seeing as most scanners do NOT cover the FM broadcast band.... it really doesn't affect us much. Sometimes if your near the transmitter site.. You may get a lil bleed in... of if the things not set just right, this can also occur,.. but its not that often,.. or that bad.
JMedley_1 said:I just bought a FM notch filter for $34.95 from www.Radiofilters.com. I mainly boug...ioFilters is all black.[/quote] Did it help?
Voyager said:milf said:Seeing as most scanners do NOT cover the FM broadcast band.... it really doesn't affect us much. Sometimes if your near the transmitter site.. You may get a lil bleed in... of if the things not set just right, this can also occur,.. but its not that often,.. or that bad.
Even though a scanner may not cover that band, desense from the transmitter is still possible - especially in the AirBand. Same with TV stations.
Joe M.
JMedley_1 said:Voyager said:milf said:Seeing as most scanners do NOT cover the FM broadcast band.... it really doesn't affect us much. Sometimes if your near the transmitter site.. You may get a lil bleed in... of if the things not set just right, this can also occur,.. but its not that often,.. or that bad.
Joe M.
From what I gather I suspect the effect on the Aircraft Band 108-136Mhz is because the FM Broadcast band is so close to it 88-107Mhz.
SAR2401 said:I have exactly the same experience as Phil with my Pro-96 using a discone on a roof mounted 30 foot mast and RG-6u cable. VHF reception was terrible compared to other scanners that I would hook up to the same antenna. I bought the $6 RS FM trap and an F to BNC adapter after reading about this on another board. The difference was night and day. Lake County S.O. on 155.970 is about 75 air miles from my location. Before I installed the FM trap, it would barely break squelch. It now comes in with almost full quieting. I saw similar improvement in all my VHF-Hi and air band reception. No degradation on any other band either. If you're using a "hot" receiver like the Pro-96, I'd sure spend the $11 it cost me for the FM trap and adapter first before buying a pre-amp since it's pretty obvious that a strong FM signal was causing front end overload and that's why VHF reception was so bad.
JMedley_1 said:The input and the output impedance of the FM trap From RadioShack is 75 ohm, the gerneral input impedance of a TV attenna input. The attenna impedance of our scanners is 50ohm.
Practically? What does that mean? I don't know. All the FM Filters designed for us scannistsastrodanco said:JMedley_1 said:The input and the output impedance of the FM trap From RadioShack is 75 ohm, the gerneral input impedance of a TV attenna input. The attenna impedance of our scanners is 50ohm.
How many times do we have to re-hash this?
The system impedance will vary by way more than 25 ohms over the low to high frequency range of the scanner. 75 vs. 50 ohm coax impedance is practically insignificant to a scanner.
JMedley_1 said:Practically? What does that mean? I don't know. All the FM Filters designed for us scannistsastrodanco said:JMedley_1 said:The input and the output impedance of the FM trap From RadioShack is 75 ohm, the gerneral input impedance of a TV attenna input. The attenna impedance of our scanners is 50ohm.
design their filters with 50ohm input and output impedance. The FM Trap from RS was not designed with us scannists in mind.
bsavery said:JMedley_1 said:Practically? What does that mean? I don't know. All the FM Filters designed for us scannistsastrodanco said:JMedley_1 said:The input and the output impedance of the FM trap From RadioShack is 75 ohm, the gerneral input impedance of a TV attenna input. The attenna impedance of our scanners is 50ohm.
Practically... meaning if you have enough signal strength at the antenna, you can overcome the loss from the impedence mis-match, the connector adaptors, and the other non-radio comms designed components.
Or... as one fellow put it.... if your trying to pull in weak signals, you might as well put your money into a decent handheld antenna and hang it off the back of your scanner before wasting your money on using CATV hardware.
BUT... there are a lot of people using it, and quite happy with it, so I guess the old saying "Your Milage May Vary" holds true for scanners too!
Bob
JMedley_1 said:You are in the dark if you use the RS FM Trap. In other words you do not know if it does attenuate the signals we want. Obviously, it lets some of our signals pass but if you want to be sure and have piece of mind you should use a FM Trap designed for scannists.
