FM Broadcast transmitters?
multisync
Heading for Dayton Hamvention in May and will probably buy a FM transitter 88- 108mhz, 1 watt version.
Anyone know what Industry Canada's rules are regarding transmitter output power?
Yea, I bought one of those cheapy, frequency drifting Radio Shack ones...GARBAGE.
to2way
Toronto
All AM/FM broadcast transmitters require licensing approval from Industry Canada. Depending on the ERP, you will have to apply for a VLPFM (very-low power FM) or LPFM (low-power FM) permit.
See the attched URL for the application form IC-2389 entitled:
Application for a Broadcasting Certificate Very Low Power FM (VLPFM) or Very Low Power Television (VLPTV) in Small Remote Communities
http://strategis.ic.gc.ca/epic/internet/insmt-gst.nsf/en/sf06113e.html
The equipment will also require a TAC (technical acceptance certificate) in order to be used in Canada. (Our equivalent to an FCC approval number).
multisync
Thanks for the reply. I visited the site. I guess the only thing I'm really looking for is the maximum amount of power I can use BEFORE I'm required to fill out the licence app. In the US I believe MAX power is 25mw.
I checked the site but it's a maze of different publications.
You wouldn't happen to have this info on the power issue?
to2way
Toronto
Applicable information is in bold text below.
Refer to document RSS-210 entitled:
RSS-210 - Low Power Licence-Exempt Radiocommunication Devices (All Frequency Bands)
http://strategis.ic.gc.ca/epic/internet/insmt-gst.nsf/en/sf01320e.html
6.2.2 (k) 88-108 MHz
The field strength shall comply with the following:
(1) not exceeding 250 microvolts/m measured at 3 metres with an averaging meter (equivalent to 19 nW
EIRP
). Any type of modulation (and carrier frequencies within the 88-108 MHz band) may be used
for this category, or
(2) not exceeding 100 microvolts/m measured at 30 metres (equivalent to 1000 µV/m measured at
3 metres, equivalent to 300 nW EIRP ) only if the modulation is FM and the carrier frequencies are
chosen from the following set: 88.1; 88.3; 88.5; 107.7; 107.9 MHz, i.e. spaced every 200 kHz.
The occupied bandwidth shall not exceed 200 kHz.
Outside this 200 kHz band (as well as outside the band 88-108 MHz),
Table 3 limits apply.
Sections 2 to 5, 6.3 to 6.6, 7 to 7.5 and 9 to 15 apply.
multisync
WOW. I think I got a Industry Canada employee replying.
Great info. Thanks
multisync
Oh well. I'll keep the RF pot turned right down or I'll walk around the lot until the signal fads just past the proerty line...or a house or two.
Those junky FM transmitters you get at eletronics stores won't make the trip to my stereo which is only 30 feet away from the computer.
multisync
That's the company who I plan on buying the FM transmitter from at Dayton.
I was looking at getting the FM35WT. $269 US.
But if your getting two houses away on that model you have I may have to reconsider my original BIG purchase.
W5JLF
D/FW Texas
When I ordered the transmitter I also ordered the 12VDC wall wart that they recommend. This wall wart induced a large AC hum into the transmitter. I then ordered the 12 VOLT 300mA SUPPLY PS-3, ($ 9.95) from http://www.dckits.com/. I placed this assembled kit in a RS 6x3x2" Project Enclosure, http://www.radioshack.com/product.asp?catalog_name=CTLG&product_id=270-1805, along with fuses on both the AC input as well as the DC output. The AC leg has an On/Off switch and a pilot light. This fixed the AC hum coming out of the transmitter. This system is on 7X24 and does not drift. I will direct email you some pictures if you want them.
Joe
SOUTH EASTERN ONTARIO ISH
fm transmitter
try a high end car audio store
I picked up one by "myron Davis" model ant-108 it has a range about 600 feet . i use it with my mp3 player and it works great . no tuning and you can select from 4 different frequencies, it is about $60 can it is about the size of a cell phone. :lol: also i found out that canadian tire is now selling for around $30.00. i have hooked mine upto my scanner and when i am traveling in a group we tune our radio to 88.7 and we all listen to the same source
Jammin_Jay
Try Ramseyelectronics.com. They sell kits as well as assembled units. They are near Rochester. NY
