i don't have that radio.
but as a shot in the dark, auto usually means default.
you are probably listening to a narrow FM transmission on FM regular.
(i will not use wide FM as it gets confusing)
and yes, listening to a narrow one will do this. and might even sound lower in volume.
from a manual
FM – There are two common types of FM (Frequency Modulation):
NFM – Narrow Band Frequency Modulation
Provides high quality communication for relatively short distance operations.
FM uses a greater frequency bandwidth than other modes.
NFM is the most common mode used above 30 MHz with the exception of the airbands. NFM is
widely used on the VHF bands: VHF marine band, 2m amateur band, 70 cm amateur band, PMR
(Private Mobile Radio) and utilities
and that is from
User manual instruction guide for Communications Receiver ARDV1 AOR USA Inc..
usermanual.wiki
