fmp24 autotune off?
kma371
I'm trying to monitor a signal on 454.35625, but FMP seems to tune to 454.350 when it's active because it has much stronger signal. is there a way to turn off what seems like an autotune feature?
mtindor
FMP24 PRO USER
Carroll Co OH / EN90LN
Yes I believe there is. Try -a0.
> fmp24 -h
<snip>
-a<num> Enable/disable auto center tuning (0-1) [-a1]
</snip>
Mike
slicerwizard
Toronto, Ontario
If FMP24 is auto-tuning to a signal that is 6.25 kHz off from the channel you're tuned to, your bandwidth setting is too large or your PPM adjustment value is wrong. FMP24 won't auto-tune to what it can't see, so obviously it's seeing the other signal, which means it's mixing that signal with your target signal and causing interference / degraded decoding, even without the auto-tuning issue.
kma371
My bandwith at the time was set to 4 so doesn't get much smaller than that. Both freqs are NEXEDGE48 systems. I'll check the PPM setting.
