DSDPlus FMP24 TCP command line syntax
ronenp
Use -oT<addr:port> on FMPA/FMPP/FMP24 command line for TCP link to remote PC.
I have tried the fiollowing line as follows : fmp24 -oT214.6.5.65:8187
and got invalid patrameter
any help welcome
Regards
R
mtindor
OH/WV DB Admin
Carroll Co OH / EN90LN
any help welcome
Regards
R
FMP24 -oT<port>
DSDPLUS -iT<addr:port>
Keep in mind that FMP24 is the listener. If you start it up on a machine, it will be listening on that machine on PORT NUMBER, TCP. You then direct DSDPlus on the remote machine to connect to the IP address and port with -iT###.###.###.###:#####
Assume the machine running FMP24 is 192.168.3.1 and you want it to listen on TCP 20001
fmp24 -oT20001
Assume the machine running DSDPlus is 192.168.3.20 and you want it to connect to FMP24.
dsdplus -iT192.168.3.1:20001
In DSDPlus CLI you'll see:
Initiating TCP connection to 192.168.3.1:20001...
Mike
slicerwizard
Toronto, Ontario
Looks like there's an error in the Notes.txt file. It says to use -oT address: port on the FMPx command line, but FMPA/FMPP/FMP24 -h all say -oT port only.
hrh17
I assume you have to open the router ports at each end for this to work? Tired remote connecting to fmp24 on a remote pc yesterday with no success
