ka3jjz
Wiki Admin Emeritus
I've seen a couple of folks using the <font> command, and finding that it doesn't work. Unfortunately our move to using CSS seems to have turned that capability off - but there is a work around which is real easy. You can use a style sheet command (no, I'm not really up on CSS), or you can use a color template command. The command is coded like this:
{{color|red|this text appears in red}}
The 2 squiggly brackets (I don't know what to call them!) are a shift of the left and right square brackets. There are 2 of them - required when calling a template.
Gotta run - yet another blasted TStorm! 73 Mike
