Ford Ranger Install Advice
FCVPI99
Rockford,IL
i have a 1998 Ford Ranger with Manual Trans
i wana mount my Pro 2055 for now and add a radio (Pro163 i think it is) later also want the Pro 96 and PSR 500 in there
i was thinking someout mounting the 2055 on the hump facing up right by the seat i dont know what drilling though the hump would do and if i would hit anything
also dont know how to mount in facing up since all i have is braket that came with radio
i have the Cell look a like off the back window wich i need to split
any one know of a good spliter that wont cost an arm and a leg
KB8QDM
Hadley/Metamora, MI
I had a '96 Ranger/manual trans with a BC-760 and a Tait xcvr mounted. What I did was construct an L bracket out of plywood. The mounting bracket for the scanner was screwed into the long leg of the L, while the short leg was pushed under the front edge of the seat (60/40 split bench). The Tait radio was then mounted to the top of the scanner using perforated steel strapping. Both radios were then mounted facing up, with enough room to clear the shifter.
Not sure on the splitter or the two handhelds.
Hope this helps.
