krazybob
I live in Running Springs. I can hear all of the repeaters. Some better than others even though I use a 6dB gain antenna tuned for 160MHz. The default output is 103.5 PL. But the repeaters are configured in such a way that if a user comes up on tone 9 for example that becomes the output tone for the repeater. It is recommended and in fact I it says so on the R5 page for Radio Reference that you monitor in CSQ mode for that very reason.I live at the foothills of the East end of the BDF and the Rx is 103.5 p.l..
"USFS repeaters commonly repeat the CTCSS tone that was used on the input for whichever mountain was used. It's recommended that all frequencies be entered in CSQ mode. In some cases where direct mode is used on the repeater output frequency, the tone may be 103.5Hz."
I use commercial radios for monitoring the forest and walk into this trap as well. As a result I program everything in CSQ. Also remember that units often times come up and talk around rather than through the repeater.
Sent from my SM-N920V using Tapatalk
