Hello, I am moving to Texas and had some questions regarding the Forth Worth / Johnson County area.
I am using a 436HP, which I have never used in a phase 2 area... how well does this work with the scanner? I also saw that there were different layers... are these layer TGs associated with the layer frequencies listed at the top of the page (because thats the only thing I could infer from). And that Johnson County is on the Johnson County simulcast frequency table? And if I wanted to listen to the combined dispatch center (RH, NRH, Haltom City...) that I would have to program the layer 2 freq table? Do any FDs simulcast or tone page on a VHF or UHF in Tarrant or Johnson county?
Sorry for all the questions, just new to the area and it is different then what we have in Ohio.
As Ben has noted, what you may be able to hear will depend greatly on your location after the move. Fort Worth proper is not using Phase II, neither are the other users on Layers 1 & 2.
Johnson County is on a separate 'layer', as are other cities using the FWRRS system. Presuming you are in either southern Tarrant or northern Johnson County, you likely will be able to also monitor the Mansfield and possibly Arlington layers. Mansfield is P25 Phase I. Arlington is using Phase II, though the PD talkgroups are encrypted. Grand Prairie and Irving are also Phase II, but likely will be out of range for you. You might be able to hear Grand Prairie if in the southeastern part of Tarrant, or northeastern Johnson County.
One layer that is not active yet is one that will be used by Midlothian & Red Oak in S/W Ellis County. I suspect you'd be able to pull that in as well. I believe it will be Phase II when activated.
There is no need to program a table for Layer 2, or any of the other layers, though of course you would need to enter the site frequencies.
It depends on where you will be monitoring, and what you want to hear. Uniden and Whistler scanners generally do not perform very well on simulcast P25 systems like the Fort Worth Regional Radio System, especially on Layers 1 and 2. Layer 1 is primarily used by Fort Worth police and is encrypted. There are some other public works users on there, but not too much interesting stuff. Layer 2 has Fort Worth Fire, Tarrant County SO, NHRW fire, police, and Forest Hill Fire and Police, with some other interesting talkgroups. You'll here the Johnson County area stuff on that site. There are some talk groups that show up on more than one site, especially the interop stuff. I don't know about Johnson County FDs simulcasting an alert tone on a conventional frequency. Denton County does that for some departments, but it's not done in Tarrant Co. Welcome to the area.
Ben,
In the last week to 10 days, I did catch one conventional tone out for Johnson County. My reception of them, even on an external antenna, is marginal, as they are "behind the hill" relative to my location. Other than that, I can't say that I have heard much activity on the Vhf conventional channels. I also can't get a good signal on their FWRRS layer, for the same reason (terrain). However, driving to Stephenville down Hwy 67, I was copying the Johnson County site until just short of Stephenville itself.
