Forts
Rouse
London
Just wanted to say thank you again for the Mem files you sent me. They had everything I was looking for and more. And that Arc246 program is the only way to go when it comes to programming that radio.
I was wondering if the Toronto FD was digital? I noticed the frequencies in your zip so I can only imagine they are not if those frequencies were used on your 246?
Also a quick question about your London FD frequencies. I noticed you have the Trunked frequencies and the Conventional frequencies under the same Quick Key. Does that mean they are grouped together and scanned together under the same Group 2?
And for anyone else in here is there a quick way to disable a Sub group within a group. What I mean is Bank 1 has sub groups 1-9. Is there a quick and easy way to disable subgroup 2 and 3 for example but let the rest scan?
Thanks guys and a big thanks goes out to Forts!!! :D
Forts
Ontario, Canada
You are very welcome for the files. As for your questions: Toronto FD is analog... no digital there. As for London Fire you are correct, I have the trunked system and the conventional channels under the same quick key.
When you want to disable subgroups here is what you do... With the radio on scan, and the group you want active, press and hold the top button on the left hand side if the radio. Now press 0 thru 9 to toggle the subgroups on and off. Releasing the top left button should send it on it's way scanning again.
