Forum marked as read error
wlmr
After I scan a forum for threads that interest me I finish by marking the forum as read using the drop down menu for this. In prior versions, this would also mark any sub-forums as also being read.
An example of this is the for sale forum with the seller feedback ratings sub-forum.
What I'm now noticing is that marking the for sale forum as read still clears the visual indication of the feedback forum but when I go one level up in the layout, I realize the feedback forum is NOT marked as read. Is this in error or do I just need to learn a new way of operating? I'd prefer that the sub-forums not falsely be shown as being read if they're not.
Another example are in the state forums where there is a breaking news forum for that state inside the state forum.
Is this being noticed by anyone else?
JESSERABBIT
Charles Town, Jefferson Co, WV
I am not seeing the headers in sub-forums show in bold blue that there are new posts. Have tried several things without success. I am logged in under my username when this happens. Any help with this problem would be greatly appreciated.
WayneH
Forums Veteran
Your master site
wlmr, why do you mark them read? After a certain time limit your cookie times out and causes all old threads to be set as read.
Jesserabbit, it sounds like a cookie issue. I have no idea otherwise.
wlmr
Habit I guess! I stumbled upon marking forums as read so that I could look at the forum list @ spot any forum I hadn't at least looked through. Also makes looking through the new posts search simpler, I can scan right past anything that isn't bolded.
As far as the cookie timing out, I have enough trouble with being logged out of the forums while my back is turned & then no longer knowing what's been looked at before.
Not a deal breaker in any instance as you may notice by the lack of my pushing the issue after my initial post back in July!
loumaag
Silent Key - Aug 2014
Katy, TX
Habit I guess! I stumbled upon marking forums as read so that I could look at the forum list @ spot any forum I hadn't at least looked through. Also makes looking through the new posts search simpler, I can scan right past anything that isn't bolded....
Just for the record, I do exactly this myself. :wink:
