From the license it appears to be a 3 frequency trunked system. It is most likely a MOTOTRBO Capacity Plus system.
Depending on your scanner model, follow the directions for programming this type of system. If you have a Uniden, you will also need to determine the LCN (Logical Channel Numbering). There is an Analyze/LCN Finder mode on some models.
You can also use software such as DSD+ with inexpensive SDRs to determine LCNs, map talkgroups, and monitor the system. DMR trunked systems are a little more difficult than P25 systems to monitor as they do not have set bandplans.
Have fun monitoring! Let us know what you find, and I will get it added to the DB.
