FPS and DEA
baj6974
Banned
FPS FREQ. 410.8 here in the Dallas area is busy this morning (digital mode) calling for Denver (which is a code name for someone) but don't know who - something mentioned about leaving the Marshals office , I take it that these are contract guards for govt bldg's?
DEA CH1 is in the clear, analog...sorry I can't remember the freq. right off hand, but busy running tags and surv. in S Dallas @ a Mc Donalds @ 11:30
ecps92
Taxachusetts
Denver - aka Bob Denver, you remember Gilligan, ole' Buddy.
Actually it's Denver Colorado.
FPS has Regional Dispatch Centers [MegaCenters] that handle much of the after hours dispatching and weekends.
Nope, most of them are full time, sworn Federal Police Officers
This forum might help more
texasemt13
CenTex DBA
Hunter, TX
baj,
Thanks! I plugged this frequency in for some San Antonio FPS listening. I can confirm that it is being used here as well, NAC 201. Just heard a smidgeon of chat earlier on my lunch break, so I'll listen for a roll call also. I'll be in Austin this weekend, so I'll try to confirm its use there...
Maybe it was an alien calling for John Denver ....
Dallas Center (DEA) Is still analog, uses some encryption and can be a blast to listen to. But if you have the DEA Aviation Channel, then it REALLY gets good.
Dallas DEA also use a VHF Channel, which is called Miller-Shilo, Mostly in the clear and still analog. its like 165.6875 or something.
baj6974
Banned
Thanks for all your input/s...410.8 kinda active today,NAC is 201 texasemt13, 415.875 is active as well, P25 and believe it may be BEP????
texasemt13
CenTex DBA
Hunter, TX
San Antonio DEA has slowly been making a switch over to P25, though analog is still common. Usually FLINT hops on the Ops freq (Ch. 3 or 4, whichever they happen to be using) and communicates with the ground. I don't believe they switch to a VHF freq (have never heard them going to "Victor" or "Uniform" for that matter, and had never heard of "Miller-Shiloh" until your post).
I wonder what the "M-S" stands for?
texasemt13
CenTex DBA
Hunter, TX
I just heard one officer tell another he went to "channel 2" (from 410.8000).
I'm wondering if this could be a completely different freq or the same freq and different NAC? I assume it could be either- but if anyone, especially in Texas, has heard them switch from 410.8000 NAC 201 to a different freq or NAC do tell.
texasemt13
CenTex DBA
Hunter, TX
I was wondering if anyone is hearing a daily roll call (I had heard that FPS used to do a daily roll call around 0700hrs)? I'd like to know the time of this, if they are still doing one. Starting to catch some good traffic on this freq, and has helped resolve an issue that davidbond and I have been trying to figure out for some time.
texasemt13
CenTex DBA
Hunter, TX
All right, for my third post in a row, I'm wondering if anyone:
a. has heard anyone refer to channel 2? I've heard on 3 occasions, a George (Contract Security Guard) unit, advise someone else to "go to Channel 2." I suspect they are using a low power (maybe even analog), unrepeated frequency for just local chatter, to not bog down "the net." I'm about 7-8 miles from downtown San Antonio so my signal is already weak, much less to catch, what I suspect, is a lower power transmission. Has anyone in Texas (Austin, El Paso, DFW, Htown) heard them switch to a channel 2?
b. happens to know what the frequency is for Ch. 2? Again I'm assuming all the FPS radios in this area were programmed the same (I imagine they would be for the whole region).
ecps92
Taxachusetts
Boston MA seems to have a 1600/1700 Roll Call vs an AM.
as for Ch.02, having seen a Radio in Boston this was a Local Rptr
not the Wide Area, at XYZ Bldg. Different NAC input, but same
area NAC output, lower-power than the Wide-Area Rptrs.
baj6974
Banned
I haven't found ch 2 either, all I can think to do is when they mention it again, go to search mode and search thru the 400-420 mhz range
baj6974
Banned
153.71?
Anyone know who this freq. belongs to here in the dallas area? It is P25 sorry, I am not sure of the NAC
baj6974
Banned
ok,thanks js and why would they be digital?
trainman111
Richmond, VA
Many radio users use digital modulation. There are quite a few utility companies around the Richmond, VA area that use P25 along with the are FD/PD's and the feds.
Miller-Shilo Rd. An Intersection close to LBJ and Miller with Two towers to the East of it. Covers NE Dallas and Garland/Sachse/Wylie really well. 165.2600 or something like that. Had a 156.7 and a 123.0 tone on it.
The DEA Aviation Channel used here is (Most of the time) 418.5750 156.7 Simplex/Repeater.
davynavy
North Richland Hills TX
You are hearing the FPS Contract Security Officers. "Denver" Mega Center dispatches all FPS federal police officers and security officers in Texas as well as most of the western US. Denver doesn't just dispatch on evenings and weekends, they are there 24/7. Sometimes you will here Philadelphia Mega Center doing radio checks.
davynavy
Fps & dea
FPS "George" units who are Contract Security Officers only have two channels on thier radios. Channel 2 is a talk around but most CSO don't know it transmits out on Channel 1 as well but doesn't hit the repeater. We catch CSO talking about things they shouldn't it took them forever to figure out how we knew. FPS actually has 9 channels in Region 7 (TX,OK,LA,NM, AR) only the federal officers radios have all the channel. FPS in this region has gone to digital radios as of this month.
Grayson County Co-op Electric is a good example of this. 4 repeated Channels operating P25. They are Digital for two reasons, A: every one else in Grayson County is and B: because they get increased range than on Analog. Less interference from crackling power lines too. Plus there are some 2 meter Ham repeaters in Tarrant County which use P25. P25 is open to anyone and any service.
N5AFD
DFW, TX
Dea-dfw
Hate resurrecting an somewhat old thread, but DEA was analog/clear on channels 1(418.625), 3(418.750) and 4(418.675) last night in the 8 o'clock hour. Dallas Comm was calling for some people on 3 and 4 and ops were running on 1. Don't know exactly where they were, but it was loud and clear in SW Arlington.
