Franklin County switching to 800 mhz
Daho
Does anyone have the talk channels for Franklin County yet? I'm starting to get some by searching for them on my scanner but not sure if I have all of them yet, nor descriptions.
N0JRD
Topeka,Ks
There are a few in the KSICS database but they are still on VHF.
firefive76
Kansas
They switched over to the state system this past week. Most of the TG's I've seen are in the lower 800's. Numbers between 804-830's is what I've heard them on so far.
Daho
I have some also. Do you have descriptions for any of them yet?
firefive76
Kansas
I've started a list of what I've heard them refer to talkgroups as:
804-Possibly EMS
805-Info
806-Ops 1
811-EMS
813-Fire
829-LE 1
831-"Channel 4"
834-PD Admin (assume Ottawa)
835-Unknown - encrypted transmissions
Daho
Also I wanted to ask, are you only using the Ottawa tower or are you using the Wellsville, Williamsburg, Rantoul, and Pomona towers?
firefive76
Kansas
I assume LE 1 just means Law Enforcement channel 1. No idea what channel 4 means. I have all of the towers in my scanner.
Daho
Ok. Cool. Seems the only tower it's been on is Ottawa. Street for me.
Daho
833 is JDC (Juvenile Detention Center)
830 is LE-2
Also, 1232 is weather statement for FR CO from Topeka
Daho
firefive76, if you have anymore or think any of mine are wrong, let me know.
mancow
N.E. Kansas
The outlier towers can carry those talkgroups but likely won't unless one happens to roam to it. Wellsville would be the most likely due to its height.
Using only the Ottawa tower will get you 99.9 % of traffic.
Daho
813 sounds to be county fire main
820 sounds like t/a for 3300 [potawatomie fire]
821 sounds like t/a for 3200 [Richmond fire]
Daho
I was wrong, 805 is Info. It sounds like, sometimes, they say SO. Also it seems like 813 in the main channel for city and county fire.
bctrainers
Olathe, KS
Can safely say that TG 829 is "Franklin County Sheriff, Law Enforcement - Channel 1".
It is designated as "SR LE 1".
Anderson County also has been using 829 to talk to Franklin County in today's recordings that I have. Vastly consisting of TG radio testing. I have also observed what appears to either be encryption(?) or a decode issue on my trunk recorder. It's hard to tell what is what from the JoCo ICS tower.
