FRCC PHASE-2 ?
Steve2003
Colorado
FRCC is definitely phase-2 capable, however Most of the stuff I have seen thus far has been Phase-1. The trick is to look at your channel grant tab.
Phase-2 transmissions will have a "/0" or "/1" after the voice frequency. This is the slot on the frequency (i.e. Phase-2 = space for two conversations on a single frequency).
Also, frequencies can alternate between phase-1 and phase-2 depending on system loads. If a talkgroup is using phase-2 and a phase-1 radio affiliates the group will revert to phase-1 mode.
You could technically see the same frequency listed three times:
853.12500
853.12500/0
853.12500/1
Also, the new Uniden scanners will show something other than "P25", "DAT" or "LNK" when receiving a phase-2 transmission. I can't remember exactly what is shows, but it is something like PS0 or PS1. I am sure you can find out somewhere in the Uniden forum.
Sent from my iPad using Tapatalk
JLM7424
Williston,ND - Williams county
853.12500
853.12500/0
853.12500/1
Uploaded 2hrs worth or so :)
ScannerSK
Gilcrest, CO
I'm not seeing any actual Phase II transmissions as of this morning. The longer they hold off switching to Phase II the better. I really don't want to change scanners again. From what I have read Weld will switch over to Phase II in stages if/when they decide to make the switch.
I never did ascertain whether the PSR-800 is capable of working on Weld's three band frequency system.
Shawn
JLM7424
As you can see in the scree pic it said Phase2 Today its pahse1 i live in Ft.Lupton and was
Pointing a 12 Element/11db yagi at their simulcast getting Good Dcd/Rcv Rate .
Maybe a Glitch in pro96com
ScannerSK
Gilcrest, CO
772.78125 is currently showing as North Metro Fire Rescue callsign WQTQ632 located in Broomfield. It appears it may be part of Adams County.
<http://wireless2.fcc.gov/UlsApp/UlsSearch/license.jsp?licKey=3575682&__newWindow=false>
Currently, tower 540 is showing as Phase 1 connected to towers 522 (Adams Simulcast), 530 (Weld Simulcast) and 555 (Fort Lupton).
Shawn
JLM7424
Shawn
Are you Able to Receive this Signal from Gilcrest? I'm not getting it in Ft.lupton
natedawg1604
Colorado
I'm getting 772.78125 from Broomfield, but it seems to be a relatively weak signal. It's possible the site is directionally aimed toward Boulder, or perhaps it's not yet operating at "full power" signal strength for testing purposes. Here is the Pro96Com tower log:
FileVersion:8
-TowerInfo
#This section is here for information only. With the exception
#of the Call Sign(s), This data is not Read back into the program at all.
System ID : 5AB
System Name : Front Range Communications Consortium (FRCC)
WACN : BEE00
Tower Number (Decimal): 5-40
Tower Number (Hex) : T0528
Tower Description :
Control Capabilities : Data,Voice,Registration
Flavor : Phase 1
Call Sign(s) :
Timestamp : Fri Jul 4 09:39:07 2014
-Tables
#Format: Table ID,Base Freq,Spacing,Input Offset,Assumed/Confirmed,BandWidth,Slots
00,851.00625,0.00625,-45.00000,"Confirmed",0.01250,1
01,762.00625,0.00625,30.00000,"Confirmed",0.01250,1
02,851.01250,0.01250,-45.00000,"Confirmed",0.01250,1
03,762.00625,0.01250,30.00000,"Confirmed",0.01250,1
04,935.01250,0.01250,-39.00000,"Confirmed",0.01250,1
05,935.01250,0.01250,-39.00000,"Confirmed",0.01250,1
-Frequencies
#Format: Channel,Usage,Frequency(/Slot),Input Channel,Input Frequency(/Slot),Input Explicit(1/0),Hit Count
"01-1584","v",771.90625,"01-1584",801.90625,0,2
"01-1644","v",772.28125,"01-1644",802.28125,0,1
"01-1684","a",772.53125,"01-1684",802.53125,0,0
"01-1724","c",772.78125,"01-1724",802.78125,0,0
-Neighbors
#Format: TowerID,TowerIDHex,System ID,Channel,Frequency,Tower Name
522,"T0516",5ab,"01-1758",772.99375,"Adams County Simulcast"
530,"T051E",5ab,"00-0369",853.31250,"Weld County Simulcast"
555,"T0537",5ab,"01-1826",773.41875,"Fort Lupton"
natedawg1604
Colorado
So far I've logged a few voice grants on Weld County Fire Dispatch & Adams SO Dispatch and an affiliation for North Metro Fire Dispatch. Also the site is broadcasting CWID "data grants" of "WQTQ632".
natedawg1604
Colorado
I would be very curious to know why, and for what purposes/agency uses, this site was constructed...
ScannerSK
Gilcrest, CO
Yes, it was fairly decent in signal strength this morning in Gilcrest however is very weak now that it is noon.
A thread from May touched on this topic and that this tower may be used to cover parts of Adams County:
http://forums.radioreference.com/colorado-radio-discussion-forum/288128-new-site-dtrs-frcc.html
Shawn
