Anyone tried Libre Office?
I tried Libre Office on a linux box. If I said Open Office, I was in error.
The script I made can be converted to windows by someone who knows windows shell programming. DD is available for windows. I'm not so sure how to remove nonprintable characters in windows since I can't find an equivalent to the unix/linux tr command.
Load up the XLS file even if it doesn't run. It has information on where the data is located in the header. Once you see that information, my script is trivial to understand.
The problem I see here is the "blocks", which by themselves have well defined boundaries, seem to be a jumbled stromg. You have to dig out the frequency information amongst a number of other characters. I had to use the text editing features of Libre Office to clean up the fields. I suspect this could be done with sed in my script, but I'm not really versed in it.
For example, this is the contents of the channel block.
VHF GuardOff121500000AM15Off20OffAutoOffOnOffOff
General AtomicsOff36500000NFM15Off20OffAutoOffOnOff
Line one is 121.5MHZ AM. Line two is 36.5MHz NFM. It looks like the frequency starts after the word "Off" and presumably "On". At some point it is easier just to write a program rather than hack with sed, awk, or similar string manipulation programs.
