Freescan 0.9M Recording Level Too Low
BenJJ
I'm using the new 0.9M Freescan with and the recording level on playback is really low. In the recording setup it seems that recording level is only controlled by the volume of the scanner. I set the volume of the scanner to the loudest bearable volume that I'd want to listen at, but the resulting recording is still to low. The recording input control panels seemed to be set at the correct levels (set at max volume).
Anyone else notice this volume playback problem?
cpuerror
Ontario, Canada
You have to setup your soundcard so the right input gets recorded. For example, you might have it plugged into line in, but its set to record from the microphone. Once you set the right record source the volume will pickup.
