Freescan 2.10 not reading scanner settings
dave3825
Suffolk County NY
I am running 2.10 on a Br330t. When I download to scanner, I thought if you uncheck all systems, it would download scanner settings to the freescan browser. It is not pulling fire tone out information. I ran butel arc330 and that pulls all the fto info with no problem. I tried freescan again and the same thing. I also downloaded the whole scanner to freescan and again, none of the fire tone out stuff is there.
I also have not ran across the bar antenna setting..
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Did you put a check in the 'Get Scanner Settings' box? E#ven if it appears to be on, I'd clear it and put it back in - uninitialized objects can do wierd things...
Assaf has been pretty backed up with work, but he usually responds to questions about apparent bugs...Mike
dave3825
Suffolk County NY
Get radio settings is checked. Unchecked and rechecked it and it still wont pull in the fto tones that are in the radio. It pulls in my correct broadcast screen and cc band settings, just not fto
