Whats New:
-New: Support for BC346XTC (needs testing)
-New: You can now abort a download
-New:CSV Export now exports more fields including NAC and number tags
-Fixed: Google Maps function & Geocoding
-Change: No longer case sensitive when uploading systems and deciding which ones to replace
-New: "REC" indicator will no longer appear in virtual control if recording is disabled
-EZ Grab now recognizes digital & analog TGIDs
-EZ Grab for TGID has an improved algorithm
-Change: Simple View is now set to off by default
-Change: If you have too many errors during an upload, they are now dealt with more gracefully
-Other improvements
I didn't get everything done that I wanted to do with this version but have to release it in the interm at least to support the 346XTC. The System Plotter is down for the count until I rewrite it to use Google's newer APIs, and remote control still isn't available but its getting close Anyways stay tuned for more.
No mention of what the 2.16A version changes are, any ideas?
I would like for FreeScan to be more simplistic with the Easy-Grab feature. Such as an Asterisk as to which columns it might grab from say Excel to import for upload.
just an fyi
Tested the new version with a display 346XTC. Programmed without a hitch.
Thanks!
Isn't it two replies ahead of yours...??
Any chance you'll be reincorporating the blue shading circle to display the radius/coverage of sites? That was really handy to have.
Good work on this latest release; glad to see you're still perfecting an already excellent program.
You should have had a window popup when you ran 2.16 that their is a new version.
That's only true if you have the 'check for update on startup' box checked in the Edit / Preferences form
Mike
