Freescan and Num Tag
hrsfoto
Paradise, CA
Is it possible to auto input sequential numbers into the 'num tag' in conventional systems? without having to input by hand hundreds/thousands?
Also, Is there a way to know how many frequencies are in a conventional system of groups? Not the whole scanner but just one cnv system?
captclint
Mountaintop, PA
You can copy the lines into Excel. Use the excel series option, and then use EZgrab to copy the excel lines back into Freescan. The ability to do this sort of thing directly is why I like ARCXT On a more practical note, if you have too many, it may be hard to remember.
this is a function of the scanner. What scanner do you have. It is a huge number. I believe it is 1000
