The 396xt has a band default setting for mode and step size.
ie, I can change the factory 108-137 range from 8.33k to 25.0k step.
From the key pad,
Menu
Settings
Band Defaults
That would be set on the channel level when you are editing frequencies in a group. Once you have defined your systems and sites then your groups are next. Things like step size, mode, alert levels, and a lot more are set up this way 73 Mike
Band settings haven't been implemented yet.. The step size for the channel group is meant for the 246 & 230 only. As YoShep said, for now you have to use the front keypad.
