I may not have explained the problem clearly.
I don't want to lock it out. I want to service search the GMRS /FRS / MURS.
What it does from the FreeScan scanner control program is instead scan Public Safety.
The hardware seems to work fine from the menu system on the physical scanner.
But I can't scan the GMRS thing when I select it in the FreeScan panel - it scans Public Service, which it does in the first selection in Service Search correctly. If I download the contents of the scanner to a FreeScan data file it should contain the correct info somewhere. Then if I upload it to the scanner it should work - I would think. But it still doesn't work from FreeScan correctly.
