In trying to load Freescan, keep getting the message "msi file must be loaded" Tried several times with Freescan 2.17, and keep getting the same message. What msi file is missing? Windows 7 is the system being used.
You are downloading the fssetup-217.zip file, then running the fssetup-217.exe file contained in that? I'm also using Windows 7.In trying to load Freescan, keep getting the message "msi file must be loaded" Tried several times with Freescan 2.17, and keep getting the same message. What msi file is missing? Windows 7 is the system being used.
The MSI is the 'install instructions', basically what installs where. For version 2.17, there is no separate msi file in the download file (it should be imbedded in the exe file). I'm thinking maybe you got a defective or incomplete download file for some reason. I'm assuming you have -.net 4.0 installed, but don't think that would generate the 'msi' error..sure I am, got the file from the Frescan site, just trying to figure out what MSI file windows or Freescan is asking about.
