Freescan Question?
N9AWO
Cataract, Indiana
Thinking about downloading Freescan for my BCD996T, BCD396T and BCT15X. How does it deal with rebanding or does it? I would be importing data from RR.
CT
In FREESCAN, you simply need to enter in the data in the areas I have circled below.
Some people pay to IMPORT directly from RR with a PAID subscription.
I use the EZGRAB function instead. (see:Free)
By highlighting and COPYING the info from the database to Windows Clipboard, then clicking EZGRAB, FREESCAN will populate the data into your Systems, Sites and Groups as needed. Even easier in Conventional Systems.
Give it a shot!
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
If you get a subscription, and download from the database, those tables are automagically filled in for you, so long as the rebanded flag is set. You know that it's set when you bring up an entry and there's a warning about rebanding there...
As an aside, I've asked Assaf to make a change so that if you manually select rebanding that the tables are also automagically filled in. Hopefully in the next release - it would save on questions like this one.
Mike
