Freescan: freescan question
W3DMV
Gettysburg, Pa
Open Freescan
Load your file
With your list visible in the left side of the computer screen,, click on
the system and then move to the right and click on the quick key down
arrow and you should see a list 1-99. Pick which one you want.
Do not click on a sub system, since you can only have 1-10 sub selections.
Aircraft < highlight this (1-99)
JFK < not this sub list (1-10 only)
Logan < not this sub list (1-10 only)
The program permits 1-99 fast keys but only 1-10 sub keys
A little confusing. Good luck
rbm
Upstate New York
Since Group Quick Keys can only be 0-9, I 'assume' you mean System Quick Keys.
Understanding Quick Keys
There are 100 'System/Site/Search Quick Keys' (0-99) and 10 'Group Quick Keys' (0-9).
Easier to Read BCD396XT Digital Scanner Manual
You can however, have multiple groups with the same GQK. (Up to a limit of 20 groups)
For System Quick Keys, just select the one you want from the 'Drop Down Box'.
I also include the SQK as the first two digits of the System Name.
It helps me keep it straight.
Rich
System Quick Keys:
rbm
Upstate New York
Rich in the pic it shows quick key 62 in my freescan it only goes to 9. I need 17
That is the System Quick Key.
I suspect that you have it confused with Group Quick Keys that do only go up to 9.
They are set when you are looking at only one specific group withing a system.
Rich
Group Quick Keys:
This many clarify a little:
In this image, the System Quick Key is in green, the Group Quick Keys are in Blue
ofd654
Ocala, Florida
if you can look at hillsborough county florida you will see what I mean
under (edc) hillsboro county its listing
(grp) then (edw) then(grp) 16 times then (edw) I would send a pic but I can not copy and paste on here
mikewazowski
Staff member
Forums Manager
Oot and Aboot
Thread moved to Scanner Programming Software forum since Freescan is not a Uniden product.
