Freescan update
AuntEnvy
Central New York
Hello all ~ I was doing some re-programming on my 396xt and wondered what the consensus was on the 2.16 version update.
I haven't updated it yet so checking to see if anyone is having any issues.
I haven't seen any recent posts/problems so I'm guessing it's good to go. ;)
AuntEnvy
Central New York
Roger that
Thanks Bob.
I'm just wondering if I should update and reload everything to my scanner now while it's hooked up or if that doesn't really affect anything performance-wise, if you will.
rbm
Upstate New York
It came out back around March of this year.
A FreeSCAN version 2.17 a thread is here.
http://forums.radioreference.com/sc...re/288020-freescan-2-17-out-freescan-ios.html
Whats New
2.17
-New: Added network streaming for compatibility with iOS
-Fixed: Slight inaccuracy in GPS range setting with conventional groups on upload to XT scanners
-Fixed: GPS Editing not showing circle radius
-Fixed: GPS System plotter is working again
This new version supports linking with FreeSCAN for iOS, which allows you to control your scanner with your iPhone. You can access this by opening up Virtual Control, and selecting the Remote Control menu than Setup. Configure the operating parameters and click Start Server. Note that FS must be run as an administrator to open the port. As well, you will need to configure your computer's firewall to allow incoming connections to FreeSCAN on the port you select (default is port 1300).
coolbass
Alstead,NH
FreeScan ver 2.17
I've tried updating and it won't proceed after the wizard box comes up, keeps saying there is an error...
I found that I had to create a new folder. Wouldn't allow me to copy over my original FreeScan folder. Hope that helps.
