Freescan Virtual Control & Recording Audio
wb2fcr
I'm using Virtual Control in Freescan for my BCT-15X on a Windows 7 desktop.
I would like to record traffic on a just a certain frequency. I have four conventional systems programmed and only one System recording setting set to "Marked" and the particular frequency "Rec Out" box checked. The other three Systems recording settings are set to off.
My issue is - if I enable recording in Virtual Control all transmissions are recorded, regardless of the System recording options settings.
Am I missing a setting somewhere to enable the "record only marked" using Virtual Control?
Thanks.
Dave
zl2taw
Brisbane, Australia
Hi Dave, have you tried turning off the record in the virtual control ?
When you start Virtual control --> Options --> Setup Recording --> Uncheck Enable Recoding
See if that helps at all, I think it then should just record the channels that are enabled for recording
Hope it works
wb2fcr
Hi Doug
Thanks for the reply. Unfortunately when I uncheck Enable Recording, nothing records at all. Not sure what's going on - maybe that's the way is supposed to work.
Dave
wb2fcr
I was just playing around with ID Tracker III. It is very flexible in regards to recording. I
I may go with Freescan to program and ID Tracker III for recording.
Thanks for the help.
Dave
CT
Have you tried ID Tracker III? It was designed with recording in mind. It does not program the scanner but it is very flexible for recording.
+5!
Great program. I use it all the time for UID logging AND recording selected systems with time stamp and UID information on the recorded file. There's plenty to tinker around with in the settings for each system too.
Also great for virtual scanner control and you can re-size the scanner window (or any window) so you can see it from across the room.
I highly recommend it. I'm at 1.7.6 but newer release is out there.
Thanks Dave!
