freescan ?
darkwolf
Oklahoma
i have been told when i load files that i need'd to click on scan in in scan modeii this correct ,what does system enable protect mean?
darkwolf
Oklahoma
also do i need tooenable unit id ?
QUOTE=darkwolf;1727289]i have been told when i load files that i need'd to click on scan in in scan modeii this correct ,what does system enable protect mean?[/QUOTE]
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Boy this is tough to understand - please get a grip on the grammer!
As to what system protect does, see that item in the FreeScan User Guide - it has a description of what that does. See the Create Systems page.
Now what about that first item?? Mike
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Re unit IDs - the 396XT is not compatible with this out of the box. You need to update the firmware - see this article which also has a table of all the Uniden models - click on the model number and you'll be taken to that scanner's TWiki article that contains the updates. Be sure to read the page completely
Updating the Firmware in Uniden DMA Scanners - The RadioReference Wiki
darkwolf
Oklahoma
i just don't understand why i'm getting other id's when i program'd the scanner oklahoma trunk system then mwcpd id's
WX5JCH
Banned
Elk City, Oklahoma
Please try to use English here in this forum, most of us don't understand your typing shortcuts. You will get more help if we can understand you. Not trying to flame, just understand what you need. State your question in a legible format and I'd be glad to help.
darkwolf
Oklahoma
ok what i'm talking about is open or closed mode how do you set that up with using freescan
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
The equivalent to open/closed mode would be ID Search or ID Scan. In ID Search you hear everything; in ID Scan you hear only those talkgroups you've programmed in your groups for your trunk system. You'll find that selection almost dead center of the trunk system setup form.
Mike
darkwolf
Oklahoma
Mike
ok thank you for the info
