I'm fairly new to SDR. Running SDR# on a RTL-SDR V3. Current interest is Military Air. I've been running band searches and logged (wrote down) several active freqs. Also have found assigned freqs for my area. Per other posts here I updated Freq Scanner (FS) to 1.4. I read in the users guide that FS "uses the database created by the standard Frequency Manager plug-in. The database is used to only scan those memorized frequencies"
So. I created a group in FM and manually entered my logged freqs. Before anyone says it, yeah, now I know that I could have done that from the band scans. Lesson learned.
Anyway, I now have a group of 'active' channels saved in a "MilAir Channels" group in FM. So, I go to FS, select "scan only memorized" and expect to scan ONLY those channels vs. a band or freq range. Unless I'm missing something it doesn't seem to work that way. Looks like it's scanning the range I'd previously set in FS. What am I doing wrong? Will FS scan a group of saved freqs? IOW, act like a standalone scanner? Do I need to use a different plugin to do this? If so PLEASE tell me I can export/import my list?
Advice and suggestions appreciated.
