Frequencies for Colorado area
K
KC0UWS
Guest
Does anybody have the frequencies that the military uses in the Colorado area? Any known VHF "highband" or "lowband" frequencies?"
kmacka
Northeast PA
Just like everyone told me to do when I asked the same question...You can use the Airnav website to lookup frequencies to your local airports, where you will hear milair from time to time. Also you can look up in the wiki the uhf artcc frequencies that milair usually use. Other than that maybe someone could hook you up with some freqs', maybe someone who lives by or around you.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
This is one area where the scanner and antenna makes all the difference - an antenna nice and high outdoors, fed with the right coax is the best solution. However, even an indoor antenna will hear milair if you know where to look, assuming you have a scanner that's capable of hearing these ranges.
I would read up on the subject here (anything in blue is a link)...
http://wiki.radioreference.com/index.php/VHF/UHF_Military_Monitoring
I would also post a query on the Colorado forum on this site, and post a question here;
http://groups.yahoo.com/group/coscanclub/
It's always better to get info from the locals in the area.
Re the ARTCC listings; the FAA supplied listings aren't always that accurate - this has been noted by several folks, including most recently, Larry Van Horn in his mil column at MT. Scroll past them and use the freqs that follow it.
73s Mike
K
KC0UWS
Guest
I do not care about ARTCC. I am looking for plain old military comm, not air comm.
The-Mad-Titan
Omaha
Well, if you don't want air traffic control then there is our day-to-day use of LMRs (Motorola/EF Johnson).
Most military comm like that is trunked - primarily Motorola systems; SmartNet/SmartZone/P25.
There are one or two MA/COM systems out there and rumor has it that the USAF is looking at EFJ P25 trunking.
Get a good scanner and you should be able to monitor local systems unless they're encrypted or frequncy hopping - then you aren't going to hear diddly squat.
firescannerbob
Colorado
The military installations in the Colorado Springs area are using 400mhz trunked systems. Check the Colorado DB here on RR for details.
