frequencies with static sound
scannerman200
North Central Alabama
On a couple of my scanners, all of a sudden, every frequency that comes in is very static. All the frequencies that come in have this static sound. What should I do?
N
nmfire10
Guest
I might help if you gave some basic information like maybe what kind of scanner, what kind of antenna, what frequencies, etc etc
K5MAR
Stillwater, OK
Check your antenna(s).
But like NMFIRE says, details, my man, details. The Devil is in the details.
Mark S.
K5MAR
Stillwater, OK
scannerman200 said:
Pro 2052 scanner. On some days the scanners frequencies come in crystal clear. I am using a outdoor antenna which is on a pole.
One, or more than one, scanner. If more than one, does each have a seperate antenna. If a common antenna, what kind of splitter? What frequencies, and how far away are the sites you are monitoring?
Mark S.
acosell
It could be a household appliance that's genterating interference... For example, when my computer monitor is on, my radio gets a lot more static then when it's off.
mciupa
Canadian DB Admin
Moderator
I'm here a lot
scannerman200 said:
I am using an outdoor antenna which is on a pole.
Are your outside antenna connections secure and protected ?
Have you had bad weather go through there lately ?
What's the closest item that is operating near your scanner ?
I'm not trying to play 20 Questions, just trying to narrow down the cause.
:wink:
K5MAR
Stillwater, OK
scannerman200 said:
These are local stations that I'm talking about. The radio I'm refering to is the pro 2052.
Previously, you said:
scannerman200 said:
On a couple of my scanners,...
So, I'll ask again:
1. One, or more than one, scanner.
2. If more than one, does each have a seperate antenna.
3. If a common antenna, what kind of splitter?
4. What frequencies
Mark S.
