Is there is such a thing as a frequency counter that will also show the subaudible tone being used by the radio transmitter? I understand some high end scanners have this feature. Perhaps there is a cheap frequency counter that does this too.
For most radios and most PCs all you need is a cable with 3.5mm plugs on both ends. One end goes into the earphone jack, the other end of the cable goes into either the microphone input or line input of your computer. Then go to the record section of the volume control mixer and unmute whichever one you are using, and adjust levels as needed. You might have to play with scanner volume and PC volume controls a bit to get good decoding.WA1ATA, that's interesting I've never thought of using a PC with tone detecting software. By connecting to the sound card does that mean I need to connect a microphone to the audio line input port of the computer?
I also have the same problem on my Windows 7 machine.Okay I got the cable (stereo). I hooked it up through my shoulder mic and I can see the left channel is carrying audio, but I can't get it to play through my computer speakers for some reason. If I record through the Dell Webcam Center it plays back just fine. None of the settings I find on Windows Vista seem to allow me to play the in-line audio through the speakers. This also might be why when I run the WinCTCSS11 program I get an exception window that reads "Cannot open device, Error 0". When I close this exception window I get the WinCTCSS on the top left of the screen, but it doesn't read any values.
Any suggestions?
