Frequency identifiers
Muffys
New London, CT
I am interested in extracting radio frequency and DPL/PL code information from 2 way radios for programming use. The information should be something like this
Frequency - between 400 - 479.995
Private Line code - 143.2 or similar
Where can I find a portable counter/reader/identifier or something to extract this information from a radio by keying the radio up?
Thanks for any help.
CatCow
Portland, OR
How much money do you want to spend? I ended up using the Close Call feature on my BCD-396 scanner to figure out the frequency and DCS code that was being used at work. If you want a device more specifically aimed at this usage and more likely to work reliably, something like the Optoelectronics Xplorer would work out well. Other options that I can think of increase in price exponentially!
Muffys
New London, CT
Well, I don't want to spend a ton of money. I have heard that the Uniden SC-230 will capture the info also, but I am not sure. I have also heard that a GY560 will work, but I don't want to buy either without knowing for sure.
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
If you have possession of the radio and just want to know what is programmed into it, take it to a radio shop and have them read the programming.
If it is not your radio and you can't do the above, then most commercial scanners have find features to locate and identify frequencies and the PL tones. There's tons of info on that in the scanner specific sections here on RR. Scanner enthusiasts have been doing this for years.
What are you planning to program that you need this frequency and PL info?
A little (read lot) more of the specifics would be really helpful here. It's difficult for us to properly help you when you don't give us the whole picture. Give us only part of the story and you're going to get a lot of answers that are way off base.
baltimorecs
Baltimore, MD
I have a handheld chinese frequency counter and it has been reliable so far. It can either be used antenna to antenna (touching) or with a jumper. My version does not show ctcss or dpl but they make one that also displays that for transmit.
Look up frequency counter for info. This is the one with ctcss display: http://www.409shop.com/409shop_product.php?id=106753
Mine is the yellow colored one and I picked it up at that store when I was in HK a few years ago.
