Frequency Step
Arvetus
Lufkin, TX
Ok, I'm having some difficulty figuring out the frequency step for some frequencies I'm programming.
I have steps of 5, 6.25, 10, 12.5, 15, 20, 25, 50 khz available.
How does one figure out what frequency step applies to the frequency you're programming?
For example, I am trying to program 155.3175. I've tried 6.25 and 12.5 and neither one works. Both rounds it down to 155.3125.
I just moved to East Texas, and I'm going through trying to reprogram my Kenwood TM-V7a. I'm using the Windows program to create my list, and then will download it to the radio.
I'm confused....
ridgescan
San Francisco, Ca.
Morning Arvetus-first,your scanner should have an 'auto' feature within the 'steps' mode, wherby it will choose the proper steps for each freq set you enter. Otherwise, your manual generally list steps for freq sets. Aside from that, maybe you're missing the 12.75 step required for that freq? I'm sure you'll get an answer here shortly--
fineshot1
NJ USA (Republic of NJ)
I'm confused....
That segment of the VHF-Hi band has been adjusted to 7.5khz steps which ham equipment will not yet do. I have compalined to icom about this and it seems to fall on deaf ears. The engineers over in japan are not in tune with the usa market.
N8IAA
Fortunately, GA
I'm confused....
When inputting the frequency, choose step size of 6.25, then put it in as 155.31625.
Larry
Arvetus
Lufkin, TX
Larry
For some reason, it won't let that go in. It keeps rounding it to 155.3125. But I put in 155.31875 and, that is only 1.75khz off, so I should still get something...we'll see.
I may just have to forget it for this particular frequency and use a real scanner instead of my ham equipment ...
