Frequency Step?
Nasby
Ohio
What frequency step would 151.1075 be? Is is 12.5 or something else? Also, is there a "trick" or formula to figuring out frequency steps?
Thx in advance!!
fineshot1
NJ USA (Republic of NJ)
That would be the new narrow band 7.5 Khz step.
151.1075 Mhz
Mhz = Million Hertz or 1000 Khz
.1 Mhz = 1000 Hz or 1 Khz
.0075 Mhz = 7.5 Khz
I think thats right or maybe I need another cup of tea
chgomonitor
Silent Key
Chicago
Vhf
But the VHF band is chopped up into different segments. You really need an accurate frequency chart showing the frequencies allocated for each channel. If you start at the bottom and work your way up in 7.5 KHz steps you'll soon be off frequency. Happy Scanning! - Ted
fineshot1
That is correct.
I do not remember where I saw one but there was a chart showing the band plan
which was revised in 2005 I think. Must be on the FCC website. I'll look around
later and see if I can find it or perhaps someone else if they know will post it.
