What frequency step would 151.1075 be? Is is 12.5 or something else? Also, is there a "trick" or formula to figuring out frequency steps?
Thx in advance!!
But the VHF band is chopped up into different segments. You really need an accurate frequency chart showing the frequencies allocated for each channel. If you start at the bottom and work your way up in 7.5 KHz steps you'll soon be off frequency. Happy Scanning! - Ted
I do not remember where I saw one but there was a chart showing the band plan
which was revised in 2005 I think. Must be on the FCC website. I'll look around
later and see if I can find it or perhaps someone else if they know will post it.
