Is there any way to change the frequency stepping in BCD996P2 in service search? It seems to step 1.25 and no way
to change it.
to change it.
Yeah, I mean that's like buying a car with no windshield wipers. No idea in the world why that's not an option.I haven't found a way either, even in quick search either, only in custom search can it be changed. If there is a way maybe someone can enlighten us...
I would think that it had to be ment that every kind of search should follow the bandplan steps, except the searches where you can program the steps. To me it sounds as a bug, if a change of step size in the bandplan have no effect to a service or quick search. @JoeBearcatWhat band? The scanner doesn't cover a 1.25khz step
MENU > SETTINGS > BAND DEFAULTS > SET STEP Read morehere
EDIT: The above steps have no effect on service searches. Best course of action would be to create a custom search for each range you want to scan and set your desired step size there
I don't know I'm about to return this thing. Now I can barely hear anything anymore. So frustrating. Everything was fine now conversations are cut off and hardly any traffic. SmhI would think that it had to be ment that every kind of search should follow the bandplan steps, except the searches where you can program the steps. To me it sounds as a bug, if a change of step size in the bandplan have no effect to a service or quick search. @JoeBearcat
/Ubbe
Two likely factors if you're listening to the system below: Encryption (all law enforcement in Franklin County is encrypted = Mode "DE") and simulcast distortionEverything was fine now conversations are cut off and hardly any traffic. Smh
But one of your primary complaints was "hardly any traffic" so.....I'm not listening to law enforcement
Oh yes I understand I think it's working again. Maybe was just nothing happening. Sorry about that.But one of your primary complaints was "hardly any traffic" so.....
I can confirm to you that Franklin County PA (and Washington County MD) are both extremely busy with fire/ems calls, and also that simulcast distortion is likely an issue for you with a 996.I don't know I'm about to return this thing. Now I can barely hear anything anymore. So frustrating. Everything was fine now conversations are cut off and hardly any traffic. Smh
Ok. Tyvm I will try that.the service search is to scan preset frequencies.
so if you are scanning the CB band there might be someone who is off 5khz from a channel.
sure he will sound off frequency, because he is.
so the way to go is to custom scan the CB range.
under settings you can get into BAND DEFAULTS and change the step size and mode.
but again, service search is set up to go through channels not frequencies.
Ok. Tyvm for your helpI can confirm to you that Franklin County PA (and Washington County MD) are both extremely busy with fire/ems calls, and also that simulcast distortion is likely an issue for you with a 996.
