Frequncy range on edacs
351stGoff
Denton, TX
I have never programmed an EDACS system on my radio before, so I don't know anything about it really. The biggest question that is stumping me at the moment, is, do the control frequencies have to be in the 800-ish range? Cause the system I want to program says to use EDACS but all the control frequencies are in the 450-ish range. I know its a relatively new system, but I want to be able to listen when I go up there for christmas in a few days (none of the systems I listen to in Texas are EDACS, so I've never needed to program one). Here is a link to the database TRS I want to program. Any helpful advice for someone with not a lot of time to learn it would be great.
http://www.radioreference.com/modules.php?name=RR&sid=2849
Thanks in advance
gmclam
Fair Oaks, CA
Edacs
Unlike Motorola, EDACS does not care what the absolute frequency is. EDACS essentially uses a "logical channel number", and that will match how you've entered the frequencies into your receiver. So when the control channel says "channel 02", it will go to the channel you've programmed into the 02 slot.
Here is a link to the RR Wiki on EDACS: http://wiki.radioreference.com/index.php/EDACS
