Fresno City Police 11?
CZ
California
Does this channel actually exist? Heard reference to it at a radio store, but no details.
kma371
I don't know if it's in use, but I have Channel 11 listed as 152.900 with a 156.7 PL. I have it listed as "Gold" with a repeater site located on Bear Mountain and it is used by SWAT and Detective Field Operations.
CZ
California
152.900 .... Ummm, I don't know. From what I've seen, all the Fresno City Police cars appear to have antennas between Cellphone size, and about 18 inches.
ECPD279
Bay Area, CA
18 inches would work perfectly on VHF. Police Call shows Fresno PD F-11 "Blue" South 160.695
CZ
California
Hm, I'll try 160.95 too, --- Notiiced "Police Call" lists it as a County Sheriff freq. though....
kma371
Sid,
Kelty's guides show two frequencies for a "South" area. One being a dispatch (SOUTH AREA 3) on 155.655 and one on 160.695 (RECORDS, Mt Sampson).
Bill
kma371
Well, I take everything I've said so far back. I was looking at the Sheriff's Office info. I don't see a channel 11 listed for Fresno City Police.
If anything channel 11 might be CLEMARS.
The cellphone-18 inch antennas could be for the MDT's. The frequencies are 860.9625, 858.9625, 857.9625, 860.2125, 855.2125.
Bill
ECPD279
Bay Area, CA
You're absolutely correct, that is an SO channel. But there's really no reason the City couldn't use it too is there?
CZ
California
I put 860.9625, 858.9625, 857.9625, 860.2125, 855.2125 in the scanner & it sounded like what I assume is Trunking of some type.
n4voxgill
Silent Key
New Braunfels, TX
I checked the FCC records and for Fresno, City Of there are 51 licenses. One of them is for Fresno, TX so it doesn't count. None of the other 50 licenses for the City of Fresno, CA authorize the use of 152.900 MHz.
Then I checked for the Fresno, County of and found 75 licenses. The county does have a licenses for 152.0075 for paging only. No license again for 152.900.
NOw this does not mean that they are not using 152.900, it just means they are not legally using the frequencies. In fact several years ago I was deposed on two criminal cases where the police had used an unlicensed frequency for bugs. Both cases were thrown out because of the unlawful act by the police, fruit of the poisonous tree.
Gill,
silaxo1
Clovis, Calif
Here are some answers to some of your posts which are way off. Ch. 11, is the simplex of Ch. 7. There is also a Ch. 12, which is the simplex of Ch. 9. Ch. 8 is CLEMARS Fresno P.D., which is on the City PL tone, and there is no Simplex of CLEMARS. Makes no sense, does it? That is because as communications goes, Fresno P.D. is in the dark ages and probably knows less about police communications than you folks on this forum.
An example of that: I was talking to the senior supervisor one day, and she told me Ch. 6, was CLEMARS. WOW! How can you work in a place 30 years plus and not know the basics. It is called no trainning at FPD.
FPD communications is in the 459 Mhz system. The in car radios are dual band, therefore also have the Sheriff's frequencies, among others, such as Fashion Fair Mall Security, Fresno State University, and so on. The six inch antenna on the trunk is for 450 Mhz. The 12 to 18 inch on the top is for the Sheriff, the black antenna on the roof is for MDS communications. On some cars there is an array of three antennas. Not allowed to say what that is for. Maybe somebody can guess. There is also a GPS antenna on the trunk.
That should answer most of your questions for the Fresno Police Dept.
SloScanMan_01
Oakridge, OR
The "forbidden three" if its in a triangle is "R.A.T. Bait" or Robbery Apprehension Team. Every bank has a little bug. If they're robbed, they slip the bug into a money packet, and notify the PD. The bug acts like a homing beacon. Every PD car has a receiver, and they can track the bad guy to his hideout..... Transmitter range is usually in the 215-222 Mhz range.
silaxo1
Clovis, Calif
You got it Slo Scan. Actually there are towers throughout the city which pick up the bait when it is stolen from wherever. This is observed in dispatch. They then notify which area is "Hot" The cars gravitate to that area and set up in different places in the area until one or more of them paicks up a signal. Then they move in for the kill. Nearly all crooks know about this now, so it ain't a worken so good. Not to mention that the people who have these things aren't keeping the batteries up. So, pretty much the equipment is obsolete.
I don't know which frequency range they are. I noticed I said Fresno PD was in the 459. That was an error. It is 450 Mhz.
CZ
California
OK, thanks for info on the Fresno City PD's 11 and 12 -- presume they would have to use PLL to run Simplex on those freq's??
GOT a new one one: heard City PD refer to Channel 14
vlarian
Central California
I have access to FPD radio equipment these are some channels that they use as far as ch9 and on I have no access to them. these channels are dead on, of note is that after 0300 to 1100 ch's 2 and 3 take there traffic to ch 1 and ch 5 takes its traffic to ch 4. ch 2, 3, 5, 6, 7 and 8 become unit to unit. Also all the patrol cars with the three little Antenna are low jack trackers. every new patrol car is equip as so.
Computer Equipment:
Data 911/DataRadio/ Trimble Model SV12D786EP 400MHZ Kit for Data 911 computer; GPDD-6085-104-10 Gemini Lite for DataRadio; SveeEight Plus, GPS Receiver for Trimble.
Software: Microsoft Windows XP Pro SP2, Data 911 Mobile Communications (MX), Automatic Vehicle Location System (AVL), Records Management System (RMS) Report Writer (RPW) Automated Field Reporting (AFR)
price for all this $15,000.00
Radio equipment:
Kenwood, Model TK-790 / TK-890 Dual band kit programmed with all Fresno PD, Fresno SO, Fresno FD, Clovis PD, Clovis FD, Fresno County Fire Protection District, Mid-valley FPD, North Central FPD, Fig-Garden FPD, Visalia PD, Fashion Fair Mall Secruity, Manchester Mall Secruity, Riverpark shopping center secruity, NOAA Weather Channels, Federal Marshals, Selma PD, etc.
(1.) 2.400 GHZ Antenna TAL-MUF24005
(1.) 806-866 MHZ antenna TAL-NM0Q800B
(1.) 3/4 inch brass mount TAL-MB8
(1.) VHF antenna TAL-QW152
price for all this $3,500.00
Fresno Police Department
Official Frequency Description
CH 1 460.0500 Southwest Dispatch
CH 2 460.2750 Central Dispatch
CH 3 460.3250 Southeast Dispatch
CH 4 460.4000 Northeast Dispatch
CH 5 460.4750 Northwest Dispatch
CH 6 460.2500 Traffic bureau / Tactical / unit to unit
CH 7 460.4250 Traffic bureau / Tactical / unit to unit
CH 8 460.0250 Mutual Aid (FPD/CPD/FSO)
