From arkansas to detroit??
dtw313
Hi all,
I am new here and recently retired from the Detroit Police Dept.I was wondering if there is a scanner that I could purchase here in Jonesboro, Arkansas and pick up Detroit Police dispatch on it or am I stuck with only getting them through Broadcastify?
Thank you all.
jonwienke
More Info Coming Soon!
VA
LOLWUT
Broadcastify is your only option if you want to hear Detroit in Arkansas.
ofd8001
Louisville, KY
Well, if you had a really, really, really tall antenna, you might.:p
On the serious side, if you still know someone in Detroit (hopefully a very technical person), you could get a scanner for them. Then by setting up a virtual private network and certain software (ProScan), you could listen to and control that scanner.
That's theoretical. The person would have to be a good friend because some maintenance (dealing with hiccups) would be on-going.
cg
Connecticut
I use Thin Clients, Proscan, and 996P2's at 3 locations to get better coverage than from my home. They use minimal electricity and bandwidth. If I need to work on them, I can use Teamviewer which I have installed.
I needed to set up the Thin Clients and do some minor network changes on the router at each location.
As of now, I do not monitor them from anywhere but my home.
chris
