FRS "Base Station" for Intercom?
03msc
RF is RF
EM45
Does anyone know of any current, for lack of a better term, 'base station' (intercom-looking) FRS radios? I'm looking to replace an old intercom from Radio Shack back in the day (it's one that utilizes the AC power wires throughout a home/business). I remember years ago seeing some that looked similar to this type of intercom (sat on a desk, had a PTT button on top, call button, channel selection, etc.) but a brief search seems to have come up empty now.
The market for them may have been close to nil and manufacturers nixed them but I thought I'd ask in case someone knows of some on the market that maybe are called something different than what I have searched.
Prefer this type to a handheld radio for this application so that's why the question. Obviously otherwise there is a myriad of handhelds that would work.
R8000
Low Battery
You could just buy a intercom system from Amazon, there's plenty of them on there.
Groeteschele
Munich
Dakota M538-BS make a MURS tabletop radio. Blackbox DMR make a VHF/UHF tabletop radio. Not know if Blackbox radio MURS or FRS or user programmable for own frequencies. Always best to get dedicated wireless tabletop intercom that has channels scrambled so neighbor don't know your family secrets like old cordless phones and baby monitors.
37a26de5-4ecd-43af-ad9a-bc903f553b88_1_1.jpg37a26de5-4ecd-43af-ad9a-bc903f553b88_1_1.jpg
jaspence
Michigan
Don't count on 2 miles with the FRS. Even 2000 feet can be a stretch. Dakota's home page is all MURS based radios. In areas without major obstruction problems, the 2 watt MURS VHF frequencies should be better than the FRS UHF radio.
russbrill
Sacramento, CA
If I remember correctly, the Rat-Shack intercoms used 49 MHz... They were good for around the house use, not much more...
n1das
Nashua, NH
View attachment 85557View attachment 85557
Those Blackbox tabletop VHF/UHF radios look suspiciously like repackaged Baofeng UV-5R radios. They probably will do everything that a regular Baofeng UV-5R will do (and just as illegally too).
iMONITOR
Silent Key
S.E. Michigan
These were the best wireless intercoms ever sold by Radio Shack! 900MHz crystal clear, good range.
85589
SteveSimpkin
Lancaster, CA
I had forgotten about those little gems... The ones I remember had the Push-to-Talk bar across the bottom and the speaker above, really plain looking... Late 70's, early 80's stuff...
The intercoms sold by Radio Shack in the 70's and 80's typically used Power Line Carrier (PLC) as the method to transport audio between stations. PLC intercom systems communicate using a very low FM frequency over your house's existing 110 volt AC house wiring that supplies power to receptacles and light fixtures. You just plug them in anywhere you have an outlet and they're ready to go. These intercoms are typically passed off as "wireless" intercoms since you do not have to install wiring between locations. They didn't always work very well.
Here are some examples from the 1980 Radio Shack catalog.
RFI-EMI-GUY
RITRON makes some UHF base stations that are wall mounted, 2 Watt and self contained except for a wall wart power supply. You can find them used on ebay. Very well made.
NWI_Scanner_Guy
SCANNING THE AIRWAVES SINCE 1987
Hammond, IN
KD8DVR
Columbus, Ohio
Those "baofengs in a box" also have no FCC certification. They are marketed as business band radios; but lack the required Part 90 certification.
DeepBlue
Columbus, Ohio
I believe the 900 MHz stuff was very wide and could not be picked up by a standard receiver? Someone refresh us on that. I know some of the 900 MHz cordless had an encoding scheme.
S.
vagrant
ker-muhj-uhn
California
You’re thinking of Spread Spectrum. Not all devices have that, even though they use 900 MHz. If one wants secure communication without a license, the Moto DTR700 is a fine device. It is more expensive than FRS, but one gets what one pays for.
For inside a home, or whatever your WiFi coverage, using the Amazon Alexa devices to talk room to room is very inexpensive and your neighbors will not listen in.
S.
