echo3whiskey
- Joined
- May 30, 2023
- Messages
- 1
Current Situation: I have a 3M and a Motorola radio that I would like to be able to use together.
3M Equipment: Peltor LiteCom Pro III (MT73H7A4D10NA). According to the manual it has capabilities in the FRS (1-14 Analog), GMRS (15-22 Analog), FRS (23-36 DMR), GMRS (37-44 DMR). For simplicity sake, let's say I am on FRS Channel 1, 462.5625MHz, Analog Modulation.
Motorola Equipment: Talkabout T631. Capabilities: GMRS/FRS (1-7), FRS (8-14), GMRS (15-22). It doesn't specify Analog, DMR, etc...
When I transmit Motorola >> 3M the 3M picks it up faint-fair. When I transmit 3M >> Motorola I hear a lot of static and barely audible voice that sometimes gets a little better or worse. Just not consistent. I have tried it over a few of the frequencies, and the experience differs very slightly - but still basically the same.
When I use the 3M to another 3M it is fine. I don't have another Motorola to verify it is perfect. I know that when I Tx on any channel with the 3M the Rx indicator on the Motorola picks up right away.
Both units have a couple of sub-channel modes - but I have those on zero or disabled to the best of my ability.
Usage: I will be in an environment where everyone else has the 3M gear. I also have the 3M unit. I wanted the flexibility to add on the Motorola radio so I could use it instead of the headset - depending on what I am doing. For instance, if I am in a quiet area, I would rather use the Motorola and give my head a break from a 12-hour day of the 3M squeezing my head like an orange.
I noticed that the 3M manual has some additional features on the *NA models (which mine is): Continuous Tone Coded Squelch System (CTCSS) and Digital Coded Squelch (DCS). The Motorola doesn't mention having those features - which are getting over my head regardless.
Anyone think of anything I am missing, or maybe even an explanation so I can just quit fooling with it?
