Ft. Carson 400 mhz System
PappyM12
Colorado Springs
Does anyone have the correct setup for a PRO-96 on Ft. Carson and Pete Air Force Base. I have programmed according to the database and hear nothing from either system. I do have all 3 CC for Carson programmed but hear id info from them. At least I think they are programmed correctly! No problems getting the AFA and new Pete system.
Jim
NeWcS
I think if you use the 'web import' in Win96 it should set it up correct for you!?!
-Jay
mpdonala
Colorado Springs
Fort Carson
Good Luck many have been trying to get thier system to work on a scanner, but with no luck. I have been trying to work with one of the Chiefs out there and get thier info but it is slow going. As soon as I come up with something I'll let everyone know.
firescannerbob
OG Feed provider
Colorado
Ditto on Marks reply. I can monitor the AFA just fine, but the data on this site for Ft Carson is incorrect.
As for PAFB, its my understanding (and this could be wrong) that its all encrypted.
eyes00only
Denver Colorado
Is it just a coincidence that there's a AFA promo on the bottom of this thread?
Jerry
AngelFire91
Anychance since you said the data on this site is wrong, you could submit an update so we might be able to change it so it could be right?
The data listed here on RR came out of one of their radios when the system first got started up and running, since then I understand they have changed some stuff around, so I'm not sure what the new stuff is.
firescannerbob
OG Feed provider
Colorado
Sure, if I had the info. Myself and Mark have both programmed our radios with the info provided and it's obviously out of date. If I had the info, I'd be glad to share it.
