Yaesu: FT50R
m0csv
Hello i havw a FT50R that seems to have low audio output, i cant find anything in manual about turning up mic gain, can any one help with problem?
thanks Bob M0CSV
jaspence
Michigan
Are you using the internal mic or external? Try whichever you don't usually use and see if that makes a difference.
AK9R
Central Indiana
From a text file that I've kept in storage for many years:
Code:
If your rig suffers from the low Tx audio problem, here's how to fix it.
1. Remove the battery and antenna.
2. Remove the "NiCd" sticker on the heat sink.
    If you remove it very carefully, it's possible to re-install it later with the same stickum that's on it.
3. Look in the cavity where you removed the sticker.  Proceeding from left to right, here's what you'll see...
    Phillips head Screw (Holds the keypad in)
    Small Silver Potentiometer (VR1001-VHF Deviation Adjustment)
    Small Silver Potentiometer (VR1002-UHF Deviation Adjustment)
    Small White Potentiometer (TC1001-DONT TOUCH!  CTCSS Tone Adjustment!!!)
4. Take a small Phillips head Screwdriver and turn both VR1001 and VR1002 about 1/8 turn clockwise.
    This will increase the VHF and UHF deviation and fix the low Tx audio problem.
    If it's not enough Tx audio, simply turn both pots another 1/8 turn.
    Make sure to turn both pots the same amount!
5. Replace the NiCd sticker, battery, and antenna.
6. You're Done!
Proceed at your own risk.
m0csv
Code:
6. You're Done!
Hi thanks everyone who had thoughts on my FT50R, i have seen those pots as i have had radio out of case several times trying to fix on off switch, in the end i changed the orange button to a tiny pusk to make switch, and now works fine every time, will try VR1001 and VR1002, and the low audio was using ths internal mic,
many thanks to all
