Ft857d/mtune
k8krh
Anyone own a YAESU FT857D..the mtune has shown up on the screen..how do we get rid of it......
it isn't effecting anything but would like to remove it.
Tnx
DOCTOR/795
kilowa22
Oregon
Mtune means you are changing the frequency or mode while in Memory mode. To switch from mtune mode you can turn the the channel/memory select knob or copy the frequency to VFO A or B.
If you are on memory channel 1 that is set for 14,313 MHz and turn the dial the radio automatically switches to mtune mode so you don't have to copy and switch to VFO A or B.
D
DaveNF2G
Guest
To get back to regular Memory mode, press the V/M button to the right of the tuning knob.
k8krh
mtune
Got it, tnx guys all is back to normal, and finally found it in manual..
DOCTOR/795
nhjay
MTUNE
My MTUNE just started showing on power up and it didn't do that before. How do I get it to stop going directly to MTUNE.
robertmac
I really hate to say this, but did you read the posts above? Especially from Dave?
nhjay
Yes I did. That will change it back but don't stop it from going back to
mtune on startup. Again. Every time I turn my radio on it goes directly to mtune.
It didn't do that before. The above solution did not fix my problem.
