I am able to read and write to my 7011 just fine but I am running into an issue with a channel I am programming which uses a 5MHz split. Here is the info on that:
TX: 457.575 156N
RX: 462.575 156N
I have thoroughly checked over the information I am programming into the radio and its correct, the repeater is working as I am test it with another radio, I am using the correct antenna, the 7011's power is set to high.
I used my SDR and another radio to determine this:
1. The radio is able to hear the output of the repeater.
2. The radio is not transmitting the 156N tone. This was checked using my SDR which was able to pickup the tone of another radio which was using the same frequency and same tone.
Some other info that may be of use:
I am using DOS to program with vertex standard's own software (version 4.10 of CE5), this is the 12 channel version of the radio.
Is there anyway to fix this?
TX: 457.575 156N
RX: 462.575 156N
