Yaesu: FTM-400XDE APRS
SA4MDN
FTM-400-XDE connected to a duel band antenna sitting about 40FT up, decent swr at 1.5.1, about 50% of the received APRS beacons activate the screen, the ones that don't activate the screen still show in the received list,
KW TH-D 74 connected to duel band antenna sitting about 2FT above ground level swr 1.5.1 all received APRS beacons activate the screen,
any reason anyone might know why half the beacons received on the 400 are in the received list but no show on the screen when received
Thanks Mick SA4MDN
vagrant
ker-muhj-uhn
California
There is a distance/milage setting, so one does not need to see beacons from far away.
W4ZWA
Benson, NC
Also I believe their was a setting in the FTM-400 that does not show duplicate stations on the screen but they still present in the received list.
SA4MDN
Range Limit is off, still looking for a duplicate station setting
ArtU
My three do not POP up Dupes. Only new since power on. Never bothered to look for a setting as I like it that way.
I "think" if stations are moving position, it is no longer a dupe like a fixed station would be.
SA4MDN
Already have the manual thanks, no setting that i can see in the manual or in the radio alone for Dupe settings, Deleting everything from the list i had it populate with beacons with only about half activating the screen and none were Dupes, not even my D74 sitting here will activate the screen every time on the 400, but the 400 will activate the 74 screen every time, it just bugs me that if they are in the list then why no screen flashing.
ArtU
And you have the Beacon Pop-Ups menu selected to all types also I am assuming? If so that is strange, but I bet mine are doing that also I always assumed it was dupes.
