FTP Error
W8WCA
/usa/oh/cmh EM89kx
I cannot read or write now - I could earlier today.
I did do some work with Sentienal then back to ProScan fwiiw
Error Reading From The Scanner.
Try Again.
ftp://192.168.0.xx/scanner.inf
System.Net.WebException: The remote server returned an error: (501) Syntax error in parameters or arguments.
at System.Net.FtpWebRequest.SyncRequestCallback(Object obj)
at System.Net.FtpWebRequest.RequestCallback(Object obj)
at System.Net.CommandStream.InvokeRequestCallback(Object obj)
at System.Net.CommandStream.Abort(Exception e)
at System.Net.FtpWebRequest.FinishRequestStage(RequestStage stage)
at System.Net.FtpWebRequest.GetResponse()
at FrmFTP.FTPBackgroundWorker_DoWork(Object sender, DoWorkEventArgs e) in \ProScan\Data_C\FrmFTP.vb:line 332
ProScan
Software Provider
Ontario, Calif.
Try again. Ensure the scanner is not in Mass Storage mode. If it happens again then power cycle the scanner.
W8WCA
/usa/oh/cmh EM89kx
It went away and worked for a while but . . .
Having same issue again.
I have power cycled the SDS200 (With ProScan not running)
Rebooted Computer
Nothing will make ftp read work and more suggestions?
Edit : A bit more info: I can Write To SDS200 via FTP but still cannot read via FTP
Also: I had used Sentenial to make changes in Favorites List - then saved to the SDS200
Then I tried to Read the SDS200 with ProScan (Nauturally afren I closed Sentenial)
W8WCA
/usa/oh/cmh EM89kx
Never mide - yet another blunder on my part:
I did not realize to Read from the scanner I had to use read only user/password
To Write I needed write user/password
