Full spectrum scan?
brpeter
Champlin, MN
I have a G5. It works amazing on the MN ARMER system. Recently I traveled outside the metro area where I didn't have any towers programmed. I had the Full spectrum scan enabled but I couldn't make it do it. I had is set to scan from 851-870. The screen would show "Out of Range" but wouldn't initiate the spectrum scan. Any ideas? Thanks.
Spitfire8520
I might be completely clueless! =)
Colorado
The G4/G5 requires that you explicitly program a wildcard site into the site list. If you do not have a wildcard site programmed, then it will do a full spectrum scan looking only for sites you have programmed (if any). In order to program a wildcard site, you need to either "FF" into both RFSS ID and Site ID. You can also force it to search for any site within a specific RFSS by programming a specific RFSS ID while leaving the Site ID as "FF."
On a side note, you could probably reduce your end range frequency to 862 MHz as there should not be any frequencies used above that.
